Hey fellas, been a while sense my last post.
So here is what I am trying to do. When I was trying to install CM12 on my Oneplus One, I pushed the rom zip file to the phone using this command...  adb push cm-12-20150221-NIGHTLY-bacon.zip /sdcard/. As a result, the file ended up being in the directory /sdcard/cm-12-20150221-NIGHTLY-bacon.zip Now I want to delete the file, but being as it is in the /sdcard/ I can't do it with a file manager, it is in a lower level storage.
post-22389-0-55789700-1426034143_thumb.j
So if anyone can give me a command to delete a file in /sdcard/ using ADB commands that would be awesome.
File name and directory is /sdcard/cm-12-20150221-NIGHTLY-bacon.zip
Thank you and Rock on!
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
https://linustechtips.com/topic/325908-help-with-andorid/
Can you not plug the device into your computer and then navigate there? You should be able to if CM is installed (...I think?) I'm not to CM so I don't really know how upgrading Cyanogen Mod goes, maybe look for help on the CM forums?
Downloading programs from CNet is not a good idea, as they will commonly include unwanted, and sometimes dangerous bloatware... The more you know.
https://linustechtips.com/topic/325908-help-with-andorid/#findComment-4426406
Because of the low level storage of the file, I cannot see it in  a file manager on android or PC. I need a ADB command. Any suggestions?
https://linustechtips.com/topic/325908-help-with-andorid/#findComment-4426453
No ideas, sorry. All I can think of would be to check the CM website/forums.
https://linustechtips.com/topic/325908-help-with-andorid/#findComment-4426464
