Hi,
    I've been doing a project for around 5 or 6 weeks now (see sig) which is using 2x Ek DDC PWM pump/res combos
http://www.ekwb.com/shop/reservoirs-and-acc/res-pump-combo/ek-ddc/ek-xres-140-ddc-3-2-pwm-incl-pump.html
One loop is for the cpu/motherboard chipset and the other is for the GPU.
I bought the bitfenix recon as it was pretty much the only white fan controller available. My plan was to use channel 1 (via a powered pwm hub) to power the 5 fans for cpu loop, channel 2 (again via powered pwm hub) to control the 3 fans of the gpu loop, leaving 4 to control the CPU loop pump and 5 (still with me?) to control the GPU loop.
However it's just rubbish lol. I have no control over the pwm hubs and no control over the PWM pumps, they just run at full speed.
I was under the impression I would be able to control pump speed using this controller, does anyone have any insight or suggestions which may help?
thanks
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/325692-bitfenix-recon-pump-control/
