C# Problem With a loop
Go to solution Solved by Guest,
The actuall Fuck?
What the balls increased my number by + 48?
(If i entered 2 it became 50)
http://stackoverflow.com/questions/9156363/console-readline-add-48-to-int
When you do (int)Console.Read() that is actually getting the ASCII value of the string "1".
As xshockz suggested, you want int.Parse("1") or int.TryParse("1", out InputInt).
The difference is that int.Parse will throw exception if the string cannot be parse. Where as int.TryParse will return false, useful if you want to repeat until valid input.
Ref: https://msdn.microsoft.com/en-us/library/f02979c7%28v=vs.110%29.aspx
https://linustechtips.com/topic/322623-c-problem-with-a-loop/#findComment-4386546
Right, it should also change the output variable to 0 or null if the parse fails if I remember correctly.
https://linustechtips.com/topic/322623-c-problem-with-a-loop/#findComment-4387071
Yes, from the MSDN:
result Type: System.Int32
When this method returns, contains the 32-bit signed integer value equivalent of the number contained in s, if the conversion succeeded, or zero if the conversion failed. The conversion fails if the s parameter is null or String.Empty, is not of the correct format, or represents a number less than MinValue or greater than MaxValue. This parameter is passed uninitialized.
https://linustechtips.com/topic/322623-c-problem-with-a-loop/#findComment-4387105
Don't cast the input to an int. Best practice would be to use Int.Parse(input)
change:
int InputInt = (int)Console.Read();
to:
int InputInt;int.TryParse(Console.ReadLine(), out InputInt);
Thanks friends, i solved it  :)
Redliquid~
https://linustechtips.com/topic/322623-c-problem-with-a-loop/#findComment-4389526
