rig i am looking at:
i5 - 4690k
Asus Strik GeForce GTX 970
4x2 8gb crucial balistik ram
i have a power supply and a case and hardrives ect but i would like to see if you guys can find anyhting about my motherboard size
i have a farley small case and i want to use it for these upgrades because i cant afford a brandnew build. my current PC is the
ACER ASPIRE XC100 i dont know what motherboard i have or the size of my case and i dont know if my parts will fit in it. please reply anmd help me out
THE CASE https://www.google.com.au/search?q=acer+aspire+xc100+case&source=lnms&tbm=isch&sa=X&ei=zhv4VPzWIOLUmAXG7YHwAQ&ved=0CAgQ_AUoAg&biw=1280&bih=911#imgdii=_&imgrc=VxWPRLrbsJLTGM%253A%3Bt2_xJvRngdYy-M%3Bhttp%253A%252F%252Fs3-ap-southeast-2.amazonaws.com%252Fwc-prod-pim%252FJPEG_300x300%252FACAT1088PC_acer_acer_aspire_xc100_pc_amd_4_black.jpg%3Bhttp%253A%252F%252Fwww.officeworks.com.au%252Fshop%252Fofficeworks%252Facer-aspire-xc100-desktop-pc-keyboard-and-mouse-acat1088pc%3B300%3B300https://www.google.com.au/search?q=acer+aspire+xc100+case&source=lnms&tbm=isch&sa=X&ei=zhv4VPzWIOLUmAXG7YHwAQ&ved=0CAgQ_AUoAg&biw=1280&bih=911#imgdii=_&imgrc=VxWPRLrbsJLTGM%253A%3Bt2_xJvRngdYy-M%3Bhttp%253A%252F%252Fs3-ap-southeast-2.amazonaws.com%252Fwc-prod-pim%252FJPEG_300x300%252FACAT1088PC_acer_acer_aspire_xc100_pc_amd_4_black.jpg%3Bhttp%253A%252F%252Fwww.officeworks.com.au%252Fshop%252Fofficeworks%252Facer-aspire-xc100-desktop-pc-keyboard-and-mouse-acat1088pc%3B300%3B300https://www.google.com.au/search?q=acer+aspire+xc100+case&source=lnms&tbm=isch&sa=X&ei=zhv4VPzWIOLUmAXG7YHwAQ&ved=0CAgQ_AUoAg&biw=1280&bih=911#imgdii=_&imgrc=VxWPRLrbsJLTGM%253A%3Bt2_xJvRngdYy-M%3Bhttp%253A%252F%252Fs3-ap-southeast-2.amazonaws.com%252Fwc-prod-pim%252FJPEG_300x300%252FACAT1088PC_acer_acer_aspire_xc100_pc_amd_4_black.jpg%3Bhttp%253A%252F%252Fwww.officeworks.com.au%252Fshop%252Fofficeworks%252Facer-aspire-xc100-desktop-pc-keyboard-and-mouse-acat1088pc%3B300%3B300
https://linustechtips.com/topic/322267-first-build-help-pls/
i5 - 4690k
From what I can find, you have an AMD chipset, so the i5 will not work. Also, the power supply is only 220w so you will need a new one for the 970.
Edit: and all it says is 'small form factor' so if say mATX
https://linustechtips.com/topic/322267-first-build-help-pls/#findComment-4380135
im on a budget of about like 1000$ so what do yoyu think i should do aBOUT MY MOTHERBOARD AND PSU and do you know if it will all fit into my tiny case? if you want i can take screenshots of my caSE\
Is that 1000 USD? If so, I don't see the problem :P
https://linustechtips.com/topic/322267-first-build-help-pls/#findComment-4380151
thank you for doing this xD im only 13 and i have been searching for like a year
Basically, you need a new power supply, and you can't get one to fit that case, so you'll need to get a new case a well.
If you can get an extra $25, this is a very good build :)
PCPartPicker part list: http://au.pcpartpicker.com/p/YLCMK8
Price breakdown by merchant: http://au.pcpartpicker.com/p/YLCMK8/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($249.00 @ CPL Online)
Motherboard: ASRock H81M Micro ATX LGA1150 Motherboard ($65.00 @ Umart)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($519.00 @ IJK)
Case: NZXT S340 (Black) ATX Mid Tower Case ($98.00 @ PLE Computers)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($92.00 @ IJK)
Total: $1023.00
Generated by PCPartPicker 2015-03-05 20:17 EST+1100
https://linustechtips.com/topic/322267-first-build-help-pls/#findComment-4380245
