800$ Gaming PC Help!
Solved by zappian,
I think im going to go with an i5, what i5 and what motherboard would you guys reccomend? I was looking at either an i5-4460 or a i5 4590. For the motherboard I am looking at the ASrock H81M and the Gigabyte GA-B85M-DS3H. Any ideas?
Get the 4440 and the ds3h board tbh.
The 4440 is great price/peformance , its the cheaper i5.
Then you can oc your 280 to about 280x levels so you will have a solid rig.
i5+ 280.
