hey i just installed my new zotac gtx 750 ti and everyting works eccept that when i run heaven benchmark on extream my core clock is only 540 mhz and memory 2700 mhz it should be higher on both what can i do? power limit on msi afterburner is 100% temp only goes to 58 c which is nice but not when the card does not run at full speed
can anybody help ? and thanks
https://linustechtips.com/topic/321708-gtx-750ti-speed-problems/
Generic reply (still try it) - Make sure that the power connector(s) for your GPU are in all the way (I would check this first)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/321708-gtx-750ti-speed-problems/#findComment-4372967
what I'd try to do next is to fiddle around with any power saving settings in Windows or perhaps NVIDIA Control Panel and see how it responds. Also is it just the benchmark? Or for every GPU usage situation
System: Intel Core i3 3240 @ 3.4GHz, EVGA GTX 960 SSC 2GB ACX 2.0, 8GB 1600MHz DDR3 Kingston HyperX RAM, ASRock B75M-DGS R2.0 Motherboard, Corsair CX430 W Power Supply
https://linustechtips.com/topic/321708-gtx-750ti-speed-problems/#findComment-4384064
