OS Partition size?
Solved by Speedbird,
I got an M.2 128gb SSD.
I want to partition it so that my OS (Windows 7 Home Premium) is on a separate partition from my programs so that I can get a clean install of windows when I want it without having to reinstall my applications. How much space should I allocate for the OS partition? I will be keeping games and data on a separate drive.
You won't need more than 60GB, but you have to reinstall your applications anyway after reinstalling Windows.
