Need help. Choosing Graphics Card
Go to solution Solved by Techdude154,
Oh yes I forgot to add it I have 500W power supply, I think I will be getting to R9 270X as lot of people say but which one should i get? MSI, Sapphire or Gigabyte?
There is hardly any difference between the cards. MSI afterburner works with all 3. The MSI card has the highest boost clock by 20 MHZ, followed by the gigabyte, followed by the Sapphire. It really comes down to the brand preference, there really is no difference
I brought this PC while ago and It have integrated graphics card in a CPU or something like this I'm not sure and I would like to get a new graphics card that will run games if possible on high performance.
So this is what I have:
Motherboard - Gigabyte F2A68HM-HD2
CPU - AMD FM2 A8 6600K Quad Core
Memory - 8GB DDR3 1600mhz
Hard Drive - 1TB Seagate
Case - Cit Goblin Greeen
I am looking to get a video card for about £100. I am thinking to get MSI GTX 750Ti for £120 but I am not sure if it will run on my system.- http://www.amazon.co.uk/MSI-1085MHz-1163MHz-DL-DVI-D-Graphics/dp/B00I602S92/ref=sr_1_1?ie=UTF8&qid=1424872804&sr=8-1&keywords=msi+750ti
If you know any better or similar video card that will run on my system please comment it. Thanks.
https://linustechtips.com/topic/317224-need-help-choosing-graphics-card/
It'll depend on your PSU. If it's 350W+ and has the necessary 6/8 pin connectors, then it'll be fine.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
a 750ti only needs 65w of power so powers up ply probably isn't an issue. a 660ti might be do able at £100 which would be a good card. or as suggested above a 270x
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
My 750ti runs comfortably on my 300W power supply, it's a good card for prebuilts, but not for anyone who has the power headroom.
Imo, depending on your power supply, you should get a R9 270 for the same price
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
If your power supply can handle it, I would get an R9 270x, that blows the 750 ti out of the water for around the same price. If you have a lower power PSU, however, the 750 ti is still a great card.
