So I replaced the Thermal paste on the gpu earlier , because the card was reaching 85 degrees under load and Idled at about 67 degrees, not after replacing the paste its idling at 84  degrees and went up to 102 degrees when I ran 3DMark.
My question is ; is this caused by too much paste ,or not enough? Also do you have any other tips to bring the temps down , because I don't think 85 under load is great anyway.
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
https://linustechtips.com/topic/31583-overheating-issues-with-hd6970/
You should post the rest of your computer specs, like the case, fan(s)? Would you say the room this computer is in is cool?
I have an Antec 300 with;
2 front 120mm intake fans(Sharkoon Silent eagle 1000),
One side (120mm ) intake,
Stock Antec 140mm top exhaust,
Stock antec 120mm rear exhaust.
The card uses the stock cooler.
CPU: FX8320 (With Arctic cooling freezer 13 pro)
and a Corsair CX600 power supply.
My motherboard is the Asus M5A99FX PRO R2.0
Cables are well managed , and the airflow in the case is good.
Room is warm only because of the computer, rest of the house is cooler.
Main Rig:
Home Server:
Anyone? :)
Main Rig:
Home Server:
I made a whole guide on how to change paste if you want to...idk look. :]
Thank you!
Main Rig:
Home Server:
Ok, so I reapplied the thermal paste, and I've gained a small temperature drop...now idling at 70-71 and peaking at 93 when running 3dMark, but this is still too high...anyone got any other ideas? Thanks
Main Rig:
Home Server:
I'm sure you've done this already, but it can't hurt to mention it. Did you clean the dust out of the heatsink? If you haven't done so for the years that you owned the card, it may be negatively affecting your heatsinks ability to dissipate heat.
| Corsair Carbide Series 350D |Corsair H100i | Intel i7 5820k @ 4.5GHz, 1.175v | EVGA x99 Micro 2 | G.Skill Trident Z 32gb, 3200MHz
| Gigabyte G1 Gaming 980Ti @1506MHz | EVGA P2 850 Watt | 2x Samsung 850 Evo 500gb | Western Digital Red Pro 6TB |
I did, it's clean....looks like I'm gonna have to get a new card, I'll use this until it burns out, (It might not I guess) but I'm not happy with it being so hot anyway
Thanks for the help :)
Main Rig:
Home Server:
