So my pc i finished a few months back all my cpu temps were fine until about 2 weeks ago.When my cpu is at 16% load temps are at 70c.I have a 3770k no over clock on it.Here is how my rad is mountedjb3b08.jpg
600T case
Corsair Link H100i temps  currently
Pump
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/31561-h100i-high-temps/
take the fans off and check for dust on the fans and the radiator.
make sure the fans are running at 100%.
try removing the cpu block cleaning off all thermal paste from the cold plate and the IHS and reapplying thermal paste.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403519
Wow! that's really bad. I can only think of 2 possible reasons. The being the most likely, that there is a fault with the pump block and it isn't actually circulating the water properly. Or, there could be an obstruction on the fin array causing the water to resist from moving. Check the screw mounts that the fin array hasn't been damaged.
Does the pump make a grinding sound (or can you hear an low audible noise from the pump block??)
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403524
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403527
Elven
^Pump has sounded the way it was since day 1 super quiet
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403529
A long shot, question, but. Do you have the stock heatsink (or possibly get your hands on an air cooler heatsink. This can determine whether the fault is cause by the H100i or a possible fault with the CPU.
I still think it's likely the H100i has some sort of fault, but just to make sure that everything is fine on the CPU side  ^_^ .
Elven
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403539
Elven
Yes but i do not have any extra thermal compound i would have to order some in
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403544
Elven
oh and i used the already on thermal compound that was on the h100i
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403546
I personally would go down this road, just to rule the factor out of the equation. Unless someone else can think of an alternative way round to figure out what the problem is. I can't confidently determine what the specific fault is.
You could try updating the firmware of the H100i if you haven't already. I have my H100i pump RPM divider set to "four". Also, try it with the side panel off. I can't imagine the case airflow being a problem, but it's another factor to rule out of the equation.
Elven
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-403567
flipped my fans so there bringing air in and it raised the temps 10c wtf?
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-405618
Elven
When you shake your rad do you hear water moving around abit? cause i do.
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-405634
you hear water when you shake your rad?? that could mean theres air in your loop and could be whats causing your problem. i would contact corsair and tell them you think you have air in your loop and they might send you a replacement, unless you tried to take yours apart or something...
RIG:|Corsair Obsidion 650d|MSI Mpower Z87| i7-4770k (4Ghz)|Corsair H100 cooler|16Gb corsair dominator platinum 1866Mhz|  EVGA GTX 780 classified (runs at 1240Mhz)| 1200W pc power and cooling silencer mkIII PSU|recon sound blaster champion series| 1Tb WD black| 256Gb Samsung 840 pro| Monitors:| Samsung px2370| ASUS VG248QE| X-star 27" 2560x1440 korean monitor (runs at 100Hz)| other stuff:| Razer black widow ultimate| Razer mamba 2013 edition| Razer Vespula mousepad| Klipsch X10i| Ultrasone Pro750| Harmon/Kardon sound sticks 2|
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-405721
never taked it apart ill send them a message and tell them. Thanks
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-405725
No problem ^_^ good luck, keep us updated!
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-405734
seems like there rma page is down ill try to call them i guess.. looks like i will have to push my lan party ... or should i just order another one on ncix 100$...
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-407600
k so i put the stock cooler on and im getting around 44 at 5% load.. really..? is it my cpu you think?
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-409279
Tested it in bl2 peaked around 70c 10c lower than my h100i today
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-409297
I know that IVY had some issues temp wise and some people de lid there CPU and re applied thermal. Honestly, what I would do is purchase stronger fans possibly something like noctua NF-12's. They are kind of expensive but probably the best you can buy really. Also what does the rest of your case's cooling situation look like I remember the Corsair 600T (your case)  I had it for a day and the thermal situation was pretty awful.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
Also, you may want to re apply your TIM. If you don't have some perhaps purchase some. I know linus uses IC Diamond. Which isn't cheap either. I have but didn't pay 30 dollars for it like NCIX is requesting. Also remember only a pea size amount you don't want to over due it.
http://us.ncix.com/products/?sku=44155&vpn=IC24&manufacture=Innovation%20Cooling
microcenter
ic diamond 24 qt
http://microcenter.com/product/401565/Innovation_Cooling_Diamond_24_Carat_Thermal_Compound_-_48_Grams
ic diamond 7 qt
http://microcenter.com/product/391498/IC_Diamond_7_Carat_Thermal_Compound_15g
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-409426
I have the same case with OC 2700k (SB) and my idle temps are ~30 with load never going over 70.
Your stock cooler seems to be doing fine, so it is probably the H100i cooler at fault?
It could be a bad mount or the H100i is not working properly.
When you put on your backplate behind the motherboard with the screws in, is it loose?
If it is, you can use rubber washers to make it tighter. I did this and my temps fell by like 10 degrees.
See the link below:
http://forum.corsair.com/v3/showthread.php?t=113707
CPU: Intel 2700k (4.7) MOBO: Asus P8Z77-V DELUXE GPU: Sapphire Vapor-X R9 290X RAM: 16GB Corsair Vengence (1866) CPU Cooler: Corsair H100i w/ 2x Noctua NF-F12 Storage: 256GB Samsung 830 Pro SSD (Boot), 64GB Crucial M4 (SSD Cache), 1TB WD Black Cavier, 2TB Hitachi, 2.5TB Buffalo Sound Card: Xonar Essence STX Case: Corsair Graphite 600t w/ full acrylic side PSU: Corsair HX750 (individually sleeved)
Peripherals: Filco Keyboard (Brown) Razer Deathadder, Sennheiser HD595, Zalman ZM-MIC1, Steelseries Qck Mass mousepad.
Pics of my Rig
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-411330
See the link below:
Thanks going to futureshop tonight to pick it up!!!%$@#%^ LOVE YA you saved me 100$++
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-413949
did it work? lol
Pics of my Rig
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-414172
did it work? lol
ill get back to your tomorrow
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-414604
So put the h100i on again with washers and temps are about the same even higher i think i put too much thermal paste on ill try again tomorrow morning
https://linustechtips.com/topic/31561-h100i-high-temps/#findComment-415401
