The Layout of the Motherboads are pretty much the Same.
But if you want +6 USB 3.0 on the I/O and want +2 Sata go with Gaming-7 (Which I am using and really enjoy)
Also the Outputs are changed to HDMI x2 and Display Port x1 and you will have 2 USB 2.0 on the I/O
Because he had a hard drive.
But if you want more USB 3.0 on the I/O and want 8 Sata 6.0Gb go with Gaming-7 (Which I am using and really enjoy)
thx for the fast answer!!
i wanna ask you about the overclocking experience?? cuz the the features you talked about doesnt really explain the price
This weekend I was planning on using it on my GPU/RAM (CPU is a Xeon E3-1231 V3 which doesn't OC) but I have heard it makes it easy and the Bios is Really useful and there is a Utility that will let you Do some stuff in Windows that you would do in the Bios
hi guys!!
planning to build my own pc stuck with choosing the right mobo
my question is what's the differance between the msi z97 gaming 5 and 7 (i like dragons so that's why i'm going for msi gaming) is the gaming 5 worth the 50$ price difference?
the gaming 7 has some extra goodies, the dragon on it is illuminated for example,...it's not worth an extra 50$ IMHO.
the gaming 7 also got 3x PCIE 3.0 X16 slots...so if you plan on running tripple R9 290's on this it's good to have, otherwise get the gaming 5.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
