I was recently watching a few of the older videos involving NAS setup, and Linus repeatedly said that they would be putting them on a 10Gbps network connection.  I'd love to setup similar configuration for my home office, but I can't find any 10Gbps switches that are actually available to purchase.  Everything I've found requires purchasing through a distributor, who almost exclusively want a contract to buy 10s of thousands of dollars worth of equipment, I only want 1 switch.
It's funny, it's not that difficult to get your hands on a 10Gbps NIC, but trying to get something to connect it to is like pulling teeth.
Could someone point me in the direction of a viable option.
https://linustechtips.com/topic/313947-10gbps-networking-options/
You dont need 10Gbps for home use, Only professional use.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
1. Not true.
2. Who said he isn't a professional.
Thats not how i meant it, I meant that the 10gbps switches are made for professional use, Thats why they are so expensive.
My Gaming PC
Cheapest 10gb switch i can find is like 1000 from netgear and only has 8 ports
You also would need 200$ ish 10gb ethernet nics
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
If youre wanting to go to 10gbps Id recommend just making the move to fiber.... You can pick up some older switches with sfp ports that are capable of handling 10gbps
But fiber optic cables are still quite expensive, depending on how much OP needs it might be cheaper to go with cat7
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
The cables themselves are not that expensive. The expensive part is the connectors and/or tools to terminate and patch fiber.
CPU: i7 3770k @ 4.8Ghz Motherboard: Sabertooth Z77 RAM: 16GB Corsair Vengeance GPU: GTX 780 Case: Corsair 540 Air Storage: 2x Intel 520 SSD Raid 0 PSU: Corsair AX850 Display(s): 1x 27" Samsung Monitor 3x 24" Asus Monitors Cooling: Swifttech H220 Keyboard: Logitech 710+ Mouse: Logitech G500 Headphones: Sennheiser HD 558 --- Internet: http://linustechtips.com/main/uploads/gallery/album_1107/gallery_12431_1107_23677.png My Setup:  http://linustechtips.com/main/gallery/image/7922-1-rkcf7io/ -- NAS: 3x WD Red 3TB Drives (RAIDZ-1), 5x 750gb Seagate ES HDD(RAIDZ-1), 120gb SSD for caching, OS: FreeNAS --  Server 1: Xeon E3 1275v2, 32GB of RAM, OS: ESXi 5.5 -- Server 2: Xeon E3 1220v2, 32GB of RAM, OS: ESXi 5.5
Well, you would need at least $1300USD for a Copper based Switch + 2xNIC. Optionally you can search on eBay for an older Cisco switch with SFP ports that can reach 10G but then you need SFP modules that can match. Not to mention optical cables, etc...
And then that's just the network. You need hardware that can actually take advantage of that network.
My suggestion would be to get a Mikrotik Switch (CRS226-24G-2S+RM) that has 24xGigabit and 2x10G SFP+ ports. Get an SFP+ NIC for the NAS and connect the NAS to 10G.
Others PCs in the network would connect to a Gigabit line meaning in IDEAL conditions you could have around 8 clients transferring to the NAS at 100MB/s. Again for all this you need SFP+ Modules that are not that cheap.
UPDATE: I did some digging on the CSR switch and it seems it can't do more than 3.2Gbps per port. So I guess an enterprise grade switch would be needed.
