epicuntiscan.info Problem
Go to solution Solved by Ptopman,
Re-install Chrome?
Ok I think I got it fixed, and Im quoting you guys so you know if this happens and maby help someone else. Looks like this virus was really embedded into my computer, I had to reset chrome, fully uninstall chrome, Delete all folders/files that had anything to do with chrome and google, use agent ransack using text "epicunitscan" on my C:/ and delete any and all files that showed up. At that point I reinstalled chrome, used sync only what I want, and only sink my bookmarks, autofill, and passwords. I have been using chrome for an hour and Malwarebytes has not blocked any outgoing or incoming IPs. So ya, I think its gone. If it comes back Ill let you guys know.
First, Im using Chrome.
So today, Malwarebytes started to block epicunitscan.info and I thought nothing of it, but now this message is poping up every 5-15sec and its really starting to piss me off.
(Picture of Malwarebytes) http://puu.sh/g2PHV/24b22d37b8.png
So I did a Malware scan and nothing came up and now Microsoft Security Essentials is not showing anything as well.
So I uninstalled Chrome, made sure ALL of Chromes files were deleted and off my computer, and re-installed, and its still happening. Im usually pretty good at getting this shit off my computer as I work with many clients who have viruses. This one has me scratching my head.
real fast, I have class in an hour from posting this so there is going to be a 3 hour window where I will not be on the forum but I will come back because this is really pissing me off. Ill edit and delete this line when I get back.
CPU: Intel i7-8700k 5GHz @ 1.35v | Cooling: EK Predator 360 | MotherBoard: ASUS z370-E | RAM: G.Skill Ripjaws V 32gb 3200MHz (4 x 8GB) | GPU: ASUS GTX 1080 TI OC
Case: Rosewill Blackhawk Ultra Modded side panel | SSD: Samsung 512gb 960 Pro | HDDS: 3TB Segate 7200rpm / 4TB HGST 7200rpm | PSU: EVGA G3 1000w | Display:ASUS VG248QE 24" / HP 25" 2511x / SAMSUNG 35" TV
Ex HDD: 3TB WD MyBook USB 3.0 | Keyboard: Rosewill MX Blue / Corsair K70 Red | Mouse: Logitech G602 | OS: Windows 10 64-bit Home Premium
https://linustechtips.com/topic/312991-epicuntiscaninfo-problem/
Re-install Chrome?
I have like I said in the post.
Check chrome extensions and run Adwcleaner
Comes up clean.
https://linustechtips.com/topic/312991-epicuntiscaninfo-problem/#findComment-4254479
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/312991-epicuntiscaninfo-problem/#findComment-4254698
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/312991-epicuntiscaninfo-problem/#findComment-4256140
Re-install Chrome?
https://linustechtips.com/topic/312991-epicuntiscaninfo-problem/#findComment-4256553
Good to know man!
https://linustechtips.com/topic/312991-epicuntiscaninfo-problem/#findComment-4258550
