Hi, I'm currently considering buying a pcie ssd specifically the Plextor M6e Black edition and have three questions about it:
1. Are they easy to wire/set up? do I need any specific connectors?
2. Can you use them as windows boot drives?
3. Can data from an old SATA SSD be easily transferred to a pcie SSD hazard-free?
https://linustechtips.com/topic/312962-pci-ssd-info/
Ah thank you very much, I was concerned about the M.2 connector but if this doesn't need it then I'll be getting the card soon (hopefully)
As long as you get the M6E with the m.2 to pcie adapter card youre fine, just dont get the standalone m.2 version
https://linustechtips.com/topic/312962-pci-ssd-info/#findComment-4254054
