I wouldn't mind waiting for the Sg13 if you think that's the right choice but I lean more towards the node 304.
CPU i5-4690k Motherboard asrock h97-ac RAM 2x4 Crucial Sport GPU Msi 4g gtx 970 Case Silverstone sg13b-q Storage western digital scorpio black 500gb PSU csm 450w Display(s) acerh27hl bmid Cooling intel stock cooler Yeah I know right Keyboard I'd rather not say Mouse logitech g602 Sound beyerdynamic dt990pro Operating System windows 8.1
https://linustechtips.com/topic/312518-best-mini-itx-case/
Corsair Graphite Series 380T
That thing is huge.
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4247872
Ncase M1 - Best all round
Cooltek W1, Prodigy - Big but can easily house a Powerfull system, supported 13''+ GPU and Largest Dual Tower cooler or thick radiator
FTZ01, RVZ02, RVZ01 - Best Steam machine, but CPU get hot too easily
Node 304 - Great case but lack of front air intakes, however can house a powerful system aswell, looks better than the SG08
250D - No where near small, can't even fit 13'' GPU, can't fit thick radiator, Bad air flow, worst air cooling options due to restricted height, can't even fit 180mm PSU, however cable management is great and looks good. imo by far the worst itx case out there
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4248865
BitFenix Prodigy. :P
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4249854
well only mini-itx I've used are some older ones but the best one so far is the bitfenix prodigy I personally use it as my gaming/lan rig but by now there should be better ones around but it's still good but dust could be a problem if you only clean once a year or so.
Live your life like a dream.
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4249987
Silverstone RVZ01 paired with either a 120mm AIO or one of the better low profile coolers.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4252055
250d, elite 130, prodigy, and sg13 are all my favorites.
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4256931
I have the Hadron Air and I love it. It's really small and looks great, just gotta be smart about what you put in it (no regular coolers on gpus, blower style coolers or kraken g10 only), and there isn't any cable management options.
You know what's easier than buying and building a brand new PC? Petty larceny!
If you're worried about getting caught, here's a trick: Only steal one part at a time. Plenty of people will call the cops because somebody stole their computer -- nobody calls the cops because they're "pretty sure the dirty-bathrobe guy from next door jacked my heat sink."
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4257088
I have a Prodigy myself, had to buy the magnetic dust filter from DemciFlex for the side panel or it'd just eat all the dust in the world.
The air flow through a Prodigy is literally too good for it's own good. Filter it up and there isn't anything for m-ITX that'll touch it in terms of air flow properties.
Shame that they made an m-ATX version, which is the opposite, the worst mATX case on the planet for air flow.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4259391
totally agree with you matey.
been planning on using some panty hose or however it's called to use as dust filter and probably just tape it in or use some kind of clamp and stick it somewhere :)
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4277996
Yeah that's what I did for the front panel :P
Didn't know about the DemciFlex custom-made options specifically for the Prodigy, but I did luckily find out about the side filter before I impatiently "fixed" that with panty hose haha. That would have been awful on the side panel. On the front panel it doesn't matter as much since there are three panels on top of eachother.
Oh and what I did was super glue around the sides of the black plastic spacer panel (the one with hexagonal big holes in it) and then quickly stretched the hose over it. Then when it was dry, I cut off the excess. It was probably not the optimal way to do it, but I was sick of dust build-up :P
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4278026
omg lol can't believe I forgot that glue existed in our world >.< hmm it's something I got to try later :) but still need to wash the panty hose it's been like stuffed in the cabinet for years no one knows how long. (It did kinda stink like dust or wood or something like that.
https://linustechtips.com/topic/312518-best-mini-itx-case/#findComment-4278148
