Problem with restarting the pc
Go to solution Solved by Rabald,
After some searching on the net i found this:
http://pcpartpicker.com/forums/topic/39 ... -7-install
Hi guys
So i build this new system:
I5 4690
Crucial 8 GB DDR3-1600
ASUS R9 290
MSI Z87-G41 PC Mate
harddrive is a hitachi 320GB
So i installed windows 7 64 bit on this system, the pc starts fine, but if i want to restart the pc these 2 things happen:
- PC starts, cpu vents turn, system vents turn
- Screen doesn't turn on, light on mouse and keyboard doesnt light up (= so not working)
If i turn off the pc by pressing the power button and restart the pc by pressing the power button again, then the pc works fine.
So my questions are:
How do i solve this? Is there a problem with the motherboard? (its new..) or a problem with the HDD ( its an older one)
https://linustechtips.com/topic/312119-problem-with-restarting-the-pc/
