Distilled Water
Solved by Ghost,
If they sold distilled water in the UK locally, what would you buy? Would you buy it locally, or have a slightly more distilled water, but you KNOW it is distilled water, not deionised online?
They don't sell distilled water locally but I would buy it if they did. It might explain how it was filtered on the bottle label and how many times.
This is what the process with well filtered water should be: http://www.lenntech.com/water-purification-steps-faq.htm
However water that has simply been boiled into steam and then condensed into water and bottled is technically distilled too and you can make that yourself if you want.
