Hi everyone!
So I'm trying to decide in a new keyboard to replace my beloved G510. I just found out that you can use Arx Control with this keyboard (I thought that it was only compatible with the G910).
So the problem is this, I'm trying to decide between the G710+ and the Razer BlackWidow Stealth (Orange Switches). But I was wondering if the arx control app only works when you have a Logitech device on your computer? I'm kind of addicted to the G510 screen to see my computer stats and if you can't use it I'm definitely going for the G710+ but I would prefer the Razer because of the audio pass through and the green scheme.
https://linustechtips.com/topic/308723-use-arx-control-without-logitech-devices/
No Logitech hardware whatsoever is required for ARX Control to function. If you have the latest version of LGS installed, you can attach the app to it and see system information and so forth. You won't be able to see information about or configure non-Logitech keyboards mice or headsets using the app, though.
Gaming mouse and racing wheel product manager for
Logitech G. Follow us on Facebook or Twitter.
^This. However if all you are wanting to do is monitor your computer stats, then I'd look into MSI Afterburner.
[witty signature]
