Hi everybody, I wanted to ask if anyone is familiar with this small computer:
http://www.banggood.com/VOYO-Smart-Mini-PC-Intel-Bay-Trail-T-CR-Z3735-Windows-8_1-Quad-Core-p-966824.html?bid=9587
I've been trying to find out information about it, some kind of review or something similar to check real performance before deciding if I should get one. Are you familiar with this? Would you consider getting one over a raspberry or something like that to avoid all the hasle?
Thanks!
pd: not sure if this is the right forum to post it.
*i7 980X @4GHz + Phanteks PH-TC14CS_BK || Gigabyte GA-X58A-OC || G.SKILL Perfect Storm 6GB @1600 CL6 || HIS Radeon HD 6970 2GB GDDR5 || Silicon Power SSD V30 60GB + WD Caviar Blue 640 GB + WD Caviar Blue 320 GB || LC POWER LEGION X2 1000W 80+ Gold ||ANTEC 900*
GG
https://linustechtips.com/topic/308715-voyo-smart-mini-pc/
I wouldn't touch that with a 10 foot pole.
Look's too sketchy. Kind of like those fake amd processors that have been floating around amazon.
CPU: I7-5820k @ 4.7 GHZ
CPU Cooler: Corsair H100I GTX
Motherboard: Asus X99 Sabertooth
Memory: Crucial Ballistix Sport LT 8x8GB (64GB Total)
Storage: 4x 850 EVO 1000GB & 1x 5TB Seagate HDD
PSU: Corsair HX1000i 80+ Platinum
GPU: EVGA Titan X 12GB SLI (2x)
Case: Corsair 400C
OS: Windows 10 Pro
Monitor: ASUS ROG PG279Q 165hz
https://linustechtips.com/topic/308715-voyo-smart-mini-pc/#findComment-4199103
