Webmin-help with raid 5
Solved by CWP,
I have a HP G5 ML350 and have set up a raid 1 and raid 5 array using the hp raid config utility. In webmin I am only able to see the smaller raid 1 array that ubuntu 14.04.1 is installed on. Any ideas ? I have already tried the webmin forum but it has been 3 days since i posted it but no one has responded.
Which modules have you been looking at to see your RAID1 array? My guess is that you have not done any partitioning, formatting and mounting on the RAID5 array yet.
Partitioning and formatting can be accomplished under Hardware -> Partitions on Local Disks.
Mounting is done via System -> Disk and Network Filesystems.
