  1. No, only Z97 boards can overclock
If  you are just gaming, a 4690K is reccomended
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/308495-b85-overclocking/#findComment-4192880
Hello guys i want to ask you if the MSI B85 g43 Gaming can overclock the Core i5 4690K to 4.2/4.4 GHz?
and is there a big diffrence between Core i5 4690K and the 4670k in Gaming? if not so i will save some money to add to another part of my build
Nope, no overclocking that I'm aware of but people have managed to find very complicated ways around it... but I wouldn't reccomend that.
The difference between the 4670 and 4690 is a better thermal interface material between the processor's heatsinc (grey case) and the actual cores within the heatsync. So the only difference is better temps.
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/308495-b85-overclocking/#findComment-4192900
