This is NOT for gaming... maybe in the future i will add a gpu... but not now.
http://pcpartpicker.com/p/Dxcy3C
Basic web browsing, light photo editing with non-professional programs, and a few 3d prints.. what do you think?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($63.99 @ SuperBiiz)
CPU Cooler: Thermaltake CLP0534 22.4 CFM CPU Cooler  ($16.99 @ SuperBiiz)
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard  ($53.99 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($101.98 @ Newegg)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($33.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($31.99 @ SuperBiiz)
Total: $362.92
Generated by PCPartPicker 2015-02-10 12:46 EST-0500
here is a cheaper build....got you a cheaper power supply and changed the SDD with something a tad bit cheaper however with more space, and changed the CPU cooler
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/308005-350-build/#findComment-4185760
you can go with a 430w spu from corsair
and maybe go with an i3 and skip the cpu cooler
^This.
For those light workloads, you can get by with this machine. When you feel like gaming, add a second 4gb stick and a GPU, and you are set to go. Btw, has Windows.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($100.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($39.89 @ SuperBiiz)
Memory: Mushkin Silverline 4GB (1 x 4GB) DDR3-1600 Memory  ($27.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ SuperBiiz)
Case: HEC Vigilance MicroATX Mini Tower Case  ($18.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($36.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($92.00 @ B&H)
Total: $360.80
Generated by PCPartPicker 2015-02-10 13:18 EST-0500
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/308005-350-build/#findComment-4186022
^This.
Total: $360.80
im a student i dont need windows :)
https://linustechtips.com/topic/308005-350-build/#findComment-4186801
How lucky you are. I'm a student too. But microsoft won't give me a windows copy, cuz fuc Brazil.
Removed Windows, added the SSD. You could remove the HD, if you don't feel the need for 1TB of storage.
Storage: Crucial V4 256GB 2.5" Solid State Drive  ($89.95 @ Amazon)
Total: $358.75
Generated by PCPartPicker 2015-02-10 15:05 EST-0500
https://linustechtips.com/topic/308005-350-build/#findComment-4186954
Total: $362.92
Thought the crucial mx100 ssd was the ssd everyone is avoiding like the plague?
https://linustechtips.com/topic/308005-350-build/#findComment-4186965
*Kingston V300
https://linustechtips.com/topic/308005-350-build/#findComment-4186986
