I upgraded my second rig from a fx 4100 to a fx 6300 and now it doesn't boot, sometimes I manage to log in to windows but then it reboots and keeps looping. I checked the temps in the BIOS and they seem to be fine, my motherboard is a Gigabyte GA-78lmt and the psu is a evga 500w bronze certified.
CPU - i7-10700K, MB -MSI Z490 Gaming PlusRAM-Corsair Vengeance Pro 3200MHz, GPU - MSI GeForce RTX 3070 GAMING X TRIO, PSU - EVGA 650w Supernova G2 80+ GoldStorage - Samsung 970 EVO 500 GB ,WD 3x Samsung 860 EVO 500GB, Cooler- Noctua NH-D15S, CASE Fractal Meshify 2 Compact
https://linustechtips.com/topic/307841-cpu-upgrade-pc-not-booting/
What bios version are you using?
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
I have the latest f4 bios
Terve!
If you haven't done that: try to reset the BIOS, just in case.
Otherwise I recommend using some kind of an old HDD, should you have one and put a fresh Windows there.
You don't have to activate it, so you will not need an other key.
If it boots with the fresh OS, I guess you have some kind of issue in your Windows.
Also, it would be nice to know what kind of loop you have.
A bluescreen? a straigtup shutdown?
Different types of problems, can indicate different parts.
Sayonara!
Sorry dude, please specifiy which version of the 78LMT you have, there is a S2P and a USB3 version of this MB
Checking Gigabyte website the USB3 version has support for vishera (6300 included) since F3 stock BIOS AND does NOT offer a F4 Bios update
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=4305
Checking the same website for the S2P version, it offers you a Bios upgrade (F5a) which will support the NEWEST bulldozer cpu´s like 6200 and adds support for the new vishera 8300
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=3833
But please double check because the 6300 is not listed in this second MB version i mention, i guess it could work with the F5a BIOS, the 8300 is the same architecture (vishera), so please clarify you have the latest bios first.
CPU AMD FX-6350 @ 4.5Ghz 1.284v Motherboard ASUS M5A97 R2.0 Memory 4x2GB ADATA XPG Gaming v2.0 1600Mhz CPU Cooler Corsair H100i
GPU MSI 270x HAWK Edition Display HP w1907 Storage 1x Samsung 850 EVO 128Gb SSD 1x 400GB Hitachi HDD Case Corsair 450D PSU Corsair CX750M Semi-modular
Keyboard Logitech G105 Blue LED Version Mouse Microsoft Basic Optical Mouse v2.0 Audio 2x Logitech x230 for a Quad-Channel speaker setup OS Windows 8.1
reset bios?
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
Make sure you have secure boot disabled.
Main Rig:
i7 4790k @ 4.4GHz w/ H75 Liquid CPU Cooler - Asus Maximus VII Hero - 16GB G.Skill Triedent X 2133MHz RAM - 2x Gtx 660s in SLI - 120GB Crucial SSD - 1TB WD HDD NZXT Hue - K70 RGB Keyboard - Corsair Sabre RGB - Windows 8.1 - 2x Asus VN247H-P 1080p Monitors (I'm a sucker for lighting effects)
Server:
FX 8350 @ 4.0GHz w/ stock cooler - 8GB Crucial 1600MHz RAM - AMD Radeon HD 7450 GPU - 300W PSU - 120GB SSD - Windows 7
