I have just try to do some FPS benchmarking for my GTX750ti , I used Fraps to Benchmark, then used Fraps Bench Reader to read Framtime file, at this point I got stuck, I dont know how to read MAX-AVG-MIN FPS in Fraps Bench Reader chart , can you guys explain how this chart show game's FPS, Give me some example :(
Above is a image that i dont know how to read and this is Framtime file : http://www.mediafire.com/view/ho6k73bewvlyzlc/TombRaider_2015-02-07_00-45-00-93_frametimes.csv
Help me pls :))
https://linustechtips.com/topic/305560-help-fraps-bench-reader/
The line that looks like this ------- is the average fps in the chart - just have to read it off the right scale. Max and min isnt a problem either then!
Its mean that i need to guess what is __ __ __ this line gonna be ?
I just confuse how do I get a exact number :P
https://linustechtips.com/topic/305560-help-fraps-bench-reader/#findComment-4153280
