display HELP pLZ
Go to solution Solved by Tahab_1,
To clear your CMOS; open your side panel and remove the silver battery looking circle, wait a minute and put it back in. That should replace BIOS.
Hey guys! I was checking to see if the intergreated graphics on my i7-4790k worked.. So I went into BIOS and changed from GTX 970 to the Intel graphics and restarted. But then it turned back on all I saw was a VERY gray screen barely and light. I went into the display manual (qnix qx2710) and appearntly onboard graphics arent compatible and a graphics card is required... So I plugged it back into the gtx 970 but now its not detected.. Help!! How do I change it back
https://linustechtips.com/topic/301998-display-help-plz/
I have an i7-4790K, I dual monitor using intel graphics and my GPU... There is definitely on board graphics, have you tried connecting your PC to a different monitor?
"Lenghts of Snakes Match Each Silent Syllable" (PTM)
Personal Build #1 Intel i7 4790K ||Sabertooth Z97 Mark 1 || Corsair H100i || 16GB Corsair Vengeance 1600mhz || Sapphire Tri-X R9 290 || 1000W EVGA PSU || Corsair Obsidian 450D  || Death Adder 2013 K70 *MX Brown*
Client Build #1 AMD FX 6300 || ASUS m5a99x EVO R2.0 || Hyper 212 Evo || 8GB Corsair Vengeance LP 1600mhz || MSI R9 280 Direct CU II || Corsair 500W || BitFenix Neos White
https://linustechtips.com/topic/301998-display-help-plz/#findComment-4103861
I don't have another monitor to test with... I know there are onboard graphics... They were enebaled and I downloaded the drivers and everything. But appearntly according to the people selling the monitor "Onboard graphics and APU chipset is not compatible."
https://linustechtips.com/topic/301998-display-help-plz/#findComment-4103872
https://linustechtips.com/topic/301998-display-help-plz/#findComment-4103876
Your TV?
https://linustechtips.com/topic/301998-display-help-plz/#findComment-4103885
trying the CMOS thing now. And we don't own a TV. We used to have one 5+ years ago and no one used it. So we never bought a new one and gave that one away.
How'd it go?
https://linustechtips.com/topic/301998-display-help-plz/#findComment-4106725
