Im trying to put together a streaming pc for a max budget of $600 US
Im going to be using it to stream from my console via a capture card, so im guessing a good cpu is needed, but what about my gpu? Will it effect the stream quality?
Any help and insight on this will be great. If you could put together a build for me that matches the budget, it would be wonderful!
Runescape player  II  Civ 6 and LoL noob  II
https://linustechtips.com/topic/299495-help-with-streaming-pc/
it was posted 3 hrs ago, and i changed some info that people wont notice if i just edit
https://linustechtips.com/topic/299495-help-with-streaming-pc/#findComment-4067320
