PSU Cable Extensions (Question)
Go to solution Solved by Vitalius,
I would like to know if using PSU extension cables (e.g 24pins to 24pins and 6pin to 6pin) reduces the power output of the PSU? Thanks in advance for your kind response. :lol: :lol:
No, it doesn't. Just don't use more than 2 in a row on the same line. Simply because that's silly.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
