wireless network keeps cutting out
Solved by EFD307,
updade: new dual band router is in aaaaand it looks like his laptop doesn't have a network card that can pick up the 5GHz signal. back to the store to get a USB dual band network card and everything's working for his laptop plus his speeds almost doubled going from 2.4 to 5GHz. 10 mbps -> 17 down and 1.5->2.5 up ping went from 32->30 all in all id call that a success.
