Hi yall, I'm looking to build my first pc, I don't need you guys to pick out the parts as I already know what I need. I need a cheap CPU for shit load amount of photo editing, and I like to sketch anime and cartoon, or mmo characters. Could you guys recommend me a software for sketching anime/cartoons? I have a bamboo graphic tablet btw. The games I play only are LoL, Maplestory, CS:GO, Dragon Ball Xenoverse and I mostly only watch videos or type up essays. My choices unfortunately are only 860K or G3258. Don't ask, i'm only 13 and I only get 30 bucks a month. I mostly game on PS4, so most of the games I run on my PC run on a potato.
https://linustechtips.com/topic/297396-first-post-rookie-help/
The 860 is the way to go since you probably won't be able to upgrade. And you can benefit from the four cores of the steamroller base since your probably editing. Could you possibly get a FX 6300 instead?
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
https://linustechtips.com/topic/297396-first-post-rookie-help/#findComment-4037196
Sell the PS4 and you just doubled your budget :lol: kidding...kind of...not really at all though
I'd wait an extra 2 months to save up for an i3. What's your total budget?
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/297396-first-post-rookie-help/#findComment-4037226
I play PS4 with friends. Well I can only afford the cpu. The rest parents are paying for... and it isn't a high budget.
https://linustechtips.com/topic/297396-first-post-rookie-help/#findComment-4037306
It doesn't have to be a high budget, just tell us the budget so we can suggest builds.
https://linustechtips.com/topic/297396-first-post-rookie-help/#findComment-4037819
