I recently got a new laptop and just went to install the GPU drivers for a GTX 970M, and while installing i got this pop up: (see picture below)
I was wodnering what intel driver i need to download because i went to the intel drivers download page and have no clue what one i need before i can install my 970m drivers haha :)
Thanks in advance :)
https://linustechtips.com/topic/297221-970m-driver-help/
Well, first, we need to know the intel igpu in the laptop
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4034944
i7 4720HQ :)
I don't believe it has Intergrated Graphics :(
ah, but you do, it is a HD 4600 (same as mine). Heres the drivers https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3720. Pick from the first two.
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035041
ah, but you do, its a HD 4600 (same as mine). Heres the drivers https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3720. Pick from the first two.
Thank you! :D
Oh really? is there a way to turn off the dedicated GPU to save battery? :)
Edit: the link you sent starts to load them redirects to the default driver page :(
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035047
Thank you! :D
Oh really? is there a way to turn of the dedicated GPU to save battery? :)
nvidia optimus should so that; It'll switch to igpu when not gaming and to the nvidia when gaming. You can manually limit the performance by also going into power management and switching to battery saver.
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035067
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035094
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24594〈=eng&ProdId=3720
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24596〈=eng&ProdId=3720
Yep that one worked, thanks a lot mate :)
Is optimus a standalone program i download or is it programmed in and activated when the drivers are installed? :)
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035106
The latter.
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035143
Okay thanks Adam :D you're a life saver :D
Haha! Have fun with your laptop . :D
https://linustechtips.com/topic/297221-970m-driver-help/#findComment-4035172
