VGA Connection
Go to solution Solved by Guest,
VGA can do 1080p at 60Hz, yes. If all the settings are correct and you don't see any visual artifacts then it should be fine.
So i have adapted on of the dvi Ports on my 980 to a vga for the middle screen and the two outer are hdmi to dvi and display port to hdmi my question is, is my vga a 1080p 60hz it says on the moniter it is and on the pc it says it is and games look smooth
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/296686-vga-connection/
what actually is artifacting and ghosting ?
1
https://linustechtips.com/topic/296686-vga-connection/#findComment-4027400
Artifacting just refers to any kind of visual anomalies that you see. Just stuff that shouldn't be there (weird colour shifting, lines on the screen, etc.). Ghosting is something else entirely, it's the pixels persisting on the screen for too long, blending into the new frame. It makes quickly moving objects look blurry, and you can see double or even triple "ghost" images trailing behind them. That's why it's called ghosting.
https://linustechtips.com/topic/296686-vga-connection/#findComment-4027421
Artifacting just refers to any kind of visual anomalies that you see. Just stuff that shouldn't be there (weird colour shifting, lines on the screen, etc.). Ghosting is something else entirely, it's the pixels persisting on the screen for too long, blending into the new frame. It makes quickly moving objects look blurry, and you can see double or even tripple "ghost" images trailing behind them. That's why it's called ghosting.
thanks
1
https://linustechtips.com/topic/296686-vga-connection/#findComment-4027423
Vga can do almost 200Hz but you need lower resolutions :^/ and it isnt digital  :^(
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/296686-vga-connection/#findComment-4027449
VGA Can handle 1080p at 60Hz
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/296686-vga-connection/#findComment-4027503
