Hey A few months back I purchased a XFX 7870 core edition and found out that it is voltage locked. Is there any way that I can unlock the voltage. Thanks in advance
FX-6300 @ 4.1 MHz; Cooler Master Hyper 212 Evo; XFX Radeon 7870 Core Edition; Arock 970 Extreme 3; Corsair CX600; Corsair Vengeance Blue 8GB(2x4GB) DDR3 @1600MHz; Seagate Barracuda 1TB; Zalman Z9 Case
Asus U43F-BBA7; i5-460M @ 2.53GHz; Crucial 8GB(2x4GB) @1333MHz; Intel 520 120GB SSD
https://linustechtips.com/topic/29656-xfx-7870-help/
Not that I know of.
I was reading somewhere and someone told me to find an older bios? What do you think of that?
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-378559
It could cause it to be unstable and other stuff by flashing to an older BIOS. The reason they put in new BIOS's is because there are updates and stuff to make it better. I personally would just leave it the way it is. What is the overclock on your GPU right now?
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-378609
Nope you cant unlock volatage, ive got XFX as well. Its not really a big problem for me but whatever.
Listen if you care.
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-378674
not overclocked at the moment
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-381007
LIAR! it says here you have 5 titans.
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-381034
Lol look at my gallery anyways you cant have 5 titans, its impossible and if it was possible then there are no drivers for it. My signature is a joke.
Listen if you care.
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-381659
 Yeah, I kinda figured that out because of your cpu. My comment was also a joke
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-383022
Maybe i should be happy, maybe i should be sad. I just dont know.
Listen if you care.
https://linustechtips.com/topic/29656-xfx-7870-help/#findComment-383031
