Hello, Guys
Well since i'm on vacation during the next months jaja I decided to use my time to build a Speaker Box to complete my set up for Gaming or Movies, my idea is a Stereo Setup 2.2, yes two, mid range 2 way set (My Focal P 135 V30)  yes it is from my car and My Subwoofer Sealed Box
The Materials that i will need are:
Full Sheet of MDF 3/4 inch
Screws
Glue
Silicon (to seal the enclosure)
Body Filler (Automotive paste)
Primer
Paint
Clear Coat
Fiber Glass
Resine
Brushes
I will start when i get paid haha like 4-7 days to buy the material
My Mid-range Set:
My 3D Enclosure Model
I Expect
Tomorrow will take borrow the camera from my sister :s
To post my Subwoofer Systems
08/07/2013
Finally
Tomorrow i'll be going to home depot to buy all the stuff i need and getting some pre-cuts to make it fit in my car. :D
https://linustechtips.com/topic/29117-summer-22-project/
Nice! I always wanted to atempt a speaker build, but don't really have the tools to accomplish such a technical project. Best of Luck!
Haha, Is a pain in the ass because alot of specs are require to design the right enclosure (Cubic Feet, Port, Materials)
The Hardware tools are Jigsaw, Circular Saw, Brushes, Staple Gun, and Sander
https://linustechtips.com/topic/29117-summer-22-project/#findComment-385288
