I've been watching tutorials and everyone has a tool for threading, but I don't really have a way of making one (Unless, there's a way that requires like no tools) Is wrapping some kind of tape around the terminals and threading them through okay? I don't want to tear anything, or break any terminals for that matter! Halp.
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
https://linustechtips.com/topic/291124-threadding-cables-through-paracord/
What are you trying to do exactly? (More specific than just sleeving cables in paracord)
Sorry, I should have been more specific. individually sleeving my whole modular PSU
For paracord it's a good idea to get a tool since it doesn't expand like PET sleeving it just makes it a lot faster to get the sleeve onto the cable. You should be able to find hollow brass or metal rods in hobby stores and some local hardware stores, just make sure to get the proper diameter, that being said it can be done without the tool but will just take more time and some fiddling.
Ah, well good luck with that, shouldn't really need a tool for it or wrapping the pins with tape, as long as you're careful it should be perfectly fine.
But how do I get the end smooth and round?
It doesn't necessarily need to be rounded but more so filed down and not sharp so it won't damage the sleeving when it slides on. I've done a little bit of paracord sleeving with a plastic tube I had on hand which worked well, I've also tried sleeving with taping the connector which works well but just takes more time to slide it on.
I have a friend who mills them out of brass to fit the female atx terminal perfectly. I sell them on http://www.mainframecustom.com/ - right now our server is going through maintenece but it will be up in the next few hours. Just search under sleeving tools and then threader.
10404170_716150161833628_343347253027605
10917363_716150155166962_523448569293539
10934074_716150145166963_140304909150552
10402418_716150131833631_401475632508692
10906393_716150135166964_119882349051116
10923456_716150138500297_771266731569503
Masking tape work (just a tiny ammount) but you need to make sure to cover all spots on the terminal and this method still sometimes snags some of the nylon fabric making the paracord look like crap.
If you can find a spare expandable antenna and then a nail big enough to stay in you can dull the nail down with some sanding and this also works. But make sure to sand it properly and smoothly otherwise your paracord will still snag on it .
[MAINFrame Customs Shop] | [Sleeving Guide Videos] | [Sleeving FAQ]
[Project Log]:[ Katharos ]: April MotM Winner | [Project Log]:[ Xýlo Kai Chalkó ]: Working | [Project Log]:[ Aspros ]: Done - 4th Place PDX Lan |
[Reason I Live]
