I got a EVGA GTX 980 SC for Christmas and everything was good for a while but suddenly I would be in the middle of a game and both of my displays would go out and the only way to get them to come back on would be to turn off the whole computer. The I've been watching the temps and everything seems fine. Is the card just faulty? Any one have an idea what's wrong?
SPECS:
CPU - i7 3770
RAM - 16gb Corsair 1600mhz
GPU - Evga GTX 980 SC
MOBO - ASUS h61m
https://linustechtips.com/topic/285951-gtx-980-help/
Nope i can still talk to my friends on teamspeak
Did you try reinstalling the drivers?
(Stupid suggestion I know but hey it could work)
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
https://linustechtips.com/topic/285951-gtx-980-help/#findComment-3883093
Some Samsung ones , it has to be the card though because before I had a Gtx 770 and never had a problem also 60hz
I would advise troubleshooting the issue at hand. ie check cables and switch them out. Reinstall the drivers for the graphics card and do a clean install. Try a different card on the monitor or the mobo integrated graphics if you have one. Make sure your gpu and power cables are connected. Troubleshoot and eliminate potential causes.
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/285951-gtx-980-help/#findComment-3883263
