Not Being credited ?
Go to solution Solved by tobben,
are you folding on the desktop client or the plugin? could you provide a screenshot
of the advanced client or chrome window?
My first guess would be that your client isn't properly set up. Maybe your forgot
to add your identity "TheGingerKid", entered the wrong passkey or something
similar? getting the most obvious out of the way first.
Otherwise, if you were having issues uploading/finishing work you should have
noticed by now, unless you are missing the deadlines. For how long do you
usually fold at a time?
So ive been folding for about a month and decided to go and look up my passkey on folding@home's website to see how many workunits and points ive accumulated only to find that it shows nothing , anyone have any idea why its not showing anything at all for me ? or suggestions on anything i could have done wrong ?
Please quote me or tag me if your trying to talk to me , I might see it through all my other notifications ^_^
the current list of dead cards is as follows 2 evga gtx 980ti acx 2.0 , 1 evga gtx 980 acx 2.0 1600mhz core 2100mhz ram golden chip card ... failed hardcore , 1 290x that caught fire , 1 hd 7950 .
may you all rest in peaces in the giant pc in the sky
https://linustechtips.com/topic/285481-not-being-credited/
https://linustechtips.com/topic/285481-not-being-credited/#findComment-3875878
Ah nevermind , ive done goofed. lel i didnt enter my passkey properly derp >.<
https://linustechtips.com/topic/285481-not-being-credited/#findComment-3875888
