Hey guys! I'm super new to overclocking. As the title states, I've never done it before or seen it done by anyone other than the stuff I've seen on YouTube (that's not real life). So, I went into my BIOS and tried overclocking based on what I've seen on the ASUS channel and what Linus could show me. I'm pretty sure I did everything right, but in CPU-Z I'm not seeing any changes. And it's showing my RAM at 980ish Mhz instead of 1866, which was how I set it in the UEFI. Maybe it's not the most reliable tool to be using to view my overclock changes?? Maybe I'm not doing something right?? Any help is always appreciated.
Thanks! Happy New Year!!!
Your attitude determines 100% of your life's outcomes. Bad Attitude, bad life. Great attitude, great life.
https://linustechtips.com/topic/281666-first-time-overclocking-help/
the ram speed is nothing, that is your "real" ram speed.
check cpu z for clock speed or core clock.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
I see "Core Speed" and it varies, but is hanging right around the 4400Mhz area, which is how I set it up, so that's good. Now I have another question. I am seeing some pretty low temps in SpeedFan. I haven't been monitoring as close as I should, but switching back and forth between gaming and SpeedFan I'm capping out around 57C which isn't that bad, right? Or is that really high? I was playing Assassin's Creed Unity for a while and I did get a crash after about an hour of gameplay. No warnings or blue screens just a system reboot. Just wondering if it's temp related.
Are you overclocking ram? I've never had good experiences with that.
anyway, DDR stands for double data rate, so 933 x 2 = 1866
My RAM can do 1866Mhz, and 2400 overclocked, but is factory clocked to 1333.. I know it doesn't make much of a difference, But I would like to get what little performance I can out of it. What's the point in having a Corvette if you're not gonna speed a little ;) Thanks for the info!
If you had a reboot, something needs more power OR you overdrew your PSU. I suggest fiddling around.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
Turned core voltage down a tad, then fired up Dragon Age: Inquisition on Ultra played for hours with no crash! I'm happy at 4.4Ghz for right now. May push for 4.8 after I get my water cooling loop going.
