Help Cpu at 100% when computer is idle
Go to solution Solved by romtec123,
Fixed.  It was Presentation font cache. how to fix: Go to C:\Windows\ServiceProfiles\LocalService\AppData\Local\ ,delete all Font*.dat and reboot.
http://puu.sh/dRvYn/00c0e98a0e.jpg That is a picture of my computer 10 minutes after starting up. I didn't run anything and the cpu is at 100% The cpu is an i5 3210m @ 2.5ghz http://puu.sh/dRwc9/93ec888362.png That is a picture of my hidden icons. (I am on a laptop)
CS Major - Verified Discord bot dev - SysAdmin
Formerly owned a server hosting company
https://linustechtips.com/topic/280807-help-cpu-at-100-when-computer-is-idle/
@romtec123
well first of these sorts of aps were removed due to major security vulnerability and are no longer supported it could just be bugged.
open task manager, click show all processor for all user and see which task is taking all the cpu power.
need to know which process is using all the CPU first before anyone can really help. Can you launch the task manager, sort the list of processes by CPU (be sure to select "show processes from all users") and then see which one is using all the cpu resources?
I'm on a horse...
Gaming Rig | Storage Server | Virtual Server | HTPC
click the CPU tab, so that we can see what program is using most of your CPU.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
lots of seperate processes individually using not very many cycles but all together adding up to about 99%... Assuming you're not doing anything at all at the time this kinda of workload shouldn't tax a 3210m. You do seem to be running a lot of background services and the thread counts of some of the processes look way too high. First step should probably be a registry scan with CCleaner and check the Windows event viewer for any obvious application log errors.
I'm on a horse...
