Ideas on modding for a 750D's SSD mounts
I own a 750D, the issue I have run into (besides Asus's Mobo being partial DOA) is I only use 2.5 " drives, mostly SSD's. This is particularly hard to run the SATA connectors to them all, I have 2 separate SATA cables running to my SSD's. only using 2 connections per strand. I have 2: Molex to 2 SATA coming in the mail, but I don't consider that a very elegant way of solving the extra cable issue I have. Does any one have any ideas? I may be purchasing a pre-sleeved kit for the PSU soon from Corsair, so there's some info if that changes anything, because my RM850's cables don't look very mod friendly. Thanks guys.
You can eliminate all sata cables and use a single molex split into sata for the two 2.5" drives and use the other molex on the chain for other things you need.
