i made one. from a plastic box
https://linustechtips.com/topic/278638-a-case-for-egpu/#findComment-3776542
I don't think im quite up for the challenge of making my own since i'm a newb when it comes to modding
if you have a mac, my guide should help you http://linustechtips.com/main/topic/277270-macbook-pro-with-a-gtx-980-setup-guide-benchmarks-egpu-setup-windows-81/
https://linustechtips.com/topic/278638-a-case-for-egpu/#findComment-3776599
Hi i was wondering if there are any budget friendly eGPU cases?
Depends if the adapter you are using for the eGPU. If using Thunderbolt then can see some example enclosures along with the implementations at link below. The most popular enclosure being the US$200 AKiTiO Thunder2, which is large enough to host the ITX style GTX670/760/970 cards:
>> DIY eGPU Implementations Hub: Thunderbolt (Tech|Inferno) <<
>> US$200 AKiTiO Thunder2 PCIe Box (16Gbps-TB2) <<
If using a EC/mPCIe interface, along with say the EXP GDC adapter, then it has a number of case options for it:
>> EXP GDC Beast/Ares-V7/V6 discussion <<
https://linustechtips.com/topic/278638-a-case-for-egpu/#findComment-3783329
