I live in holland and I want to know if I can order the parts from another country (Germany), but will it still function right in my country?
here is my build:
- CPU: i5 4590
- GPU: xfx amd r9 280
- RAM: 8gb crucial ballistix
- Mobo: Asrock b85m pro4
- HDD: 1tb seagate
- 450 watt Be quiete! system power 7 80+ silver
here is the link:
https://www.mindfactory.de/shopping_cart.php
Will the power supply be able to power everything?
thanks for answering.
https://linustechtips.com/topic/278377-i-need-the-help/
here is my build:
- CPU: i5 4590
- HDD: 1tb seagate
here is the link:
Should work fine but why not order in the netherlands?
https://linustechtips.com/topic/278377-i-need-the-help/#findComment-3773804
i dont think where you get your parts will make them not work where you live i dont think they region lock parts and by i dont think i mean i highly doubt it
https://linustechtips.com/topic/278377-i-need-the-help/#findComment-3774168
For your power supply, here are the numbers i calculated for maximum usage:
  • CPU: 84 W TDP (you can design to 1.5x...126 W but 84 should cover the nominal situation)
  • Memory: 5 W per stick (10 W in your case)
  • Motherboard: 45-90 W (this one is a bit more difficult to determine, if all else fails, go with 90W)
  • Graphics Card: 375 W (on board (75W) + 2x 8pin (150W))
  • Cooling: 20 W (4 x 5 W for case and cpu fans)
  • HDD: 5 W (1 TB)
So, if you take those values, you get about 626 W at max load (at nominal, you would see about 260-280 W).
My personal preference is to design or the max values and ensure good efficiency at nominal. However, if you care about just the nominal, if you rarent going to be taxing the system, then go with something a bit smaller. However, I would recommend a 600-650 W.
As for whether it would work, right out of the box, i would say yes in terms of voltage but no if you need different plugs.
https://linustechtips.com/topic/278377-i-need-the-help/#findComment-3774243
