I upgraded my mobo cpu today and everything thing was working fine. I shut it down about 6 hours ago when I was out for dinner but now when I boot my keyboard and mouse don't work and I get a screen that says ' Reboot and select proper boot device. Or insert boot media in selected boot device and press any key.' I'm stuck for what it could be, any help is appreciated.
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/277093-system-not-booting/
Check connections to your hard drives/ssd, both power and data cables. If that didn't work, go into the BIOS and see if your main OS drive appears, if it does, select it as the #1 boot priority. Last thing I would try is a BIOS reset like XxSwankeyxX just said. Just wait like 10 - 15 mins before putting the mobo battery back in while power to the PSU is disconnected.
https://linustechtips.com/topic/277093-system-not-booting/#findComment-3795231
