im not sure where this post should go but... could someone reccomend me a decent fan controller? i have 5 fans (2 intake, 2 in pull for my rad and 1 exhaust) i cant control 4 with Corsair Link or the mobo (RPMs dont change no matter what)
Addon: 200th post :D
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
https://linustechtips.com/topic/274382-fan-controller/
This is the controller I would recommend especially if your using PWM fans. Link (NZXT Sentry 3)
Quantum Chaos: i7 6850K | 2x Strix 1080Ti SLI | MSI X99 SLI Krait | 32GB Corsair Vengeance LPX | Samsung 970 EVO 500GB | 3TB WD Red RAID 1
https://linustechtips.com/topic/274382-fan-controller/#findComment-3725986
well i have 3 pin Corsair SP 120s... will those work? (the front ones are CM Storms LED ones that come with the Scout II)
https://linustechtips.com/topic/274382-fan-controller/#findComment-3726044
Yes they will, It only supports 5 fans though so no room for expansion without splitters.
https://linustechtips.com/topic/274382-fan-controller/#findComment-3726064
