What is "Mouse Acceleration"
Go to solution Solved by A Bubble,
Lets say you moved your mouse 1 inch per second for 5 seconds and it moved the cursor 50 pixels. That's 10 pixels per inch of movement.
Now, lets say you moved your mouse 3 inches per second for 5 seconds, the logical answer would be that it moves the cursor 150 pixels. With acceleration this could be 200 for example, basically anything more than what you'd expect.
In competitive play etc, this can make a HUGE difference.
I've never had an issue with mouse sensitivity/speed, and now I hear topics about "disabling mouse acceleration" [never done it, never needed too, never had an issue with my mouse]
Youtube is no help; can somebody shed some techquickie light on this "mouse acceleration" thing and how it differs from "mouse speed/sensitivity"
Thanks!
https://linustechtips.com/topic/272115-what-is-mouse-acceleration/
A horrible disease..
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
Thanks!
no mouse acceleration.
the distant you move your mouse moves your cursor the same number of pixels every time regardless of speed of mouse
mouse acceleration
if you move your mouse the same distant but at different speeds the cursor travels different distances. eg you move your mouse fast you go flying, you move your mouse slowly it barley moves
i know it is athene and huge razer product placement but they explain what it is
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
Mouse acceleration is when the mouse increases it's sensitivity when you move it faster, and lowers the sensitivity when you move it slower.
With mouse acceleration OFF, moving the mouse a certain distance at any speed (fast or slow) will always cause the cursor to move the exact same distance.
With mouse acceleration ON, moving the mouse a specific distance fast will cause the cursor to move farther than if you had moved the same distance slowly.
i7 not perfectly stable at 4.4.. #firstworldproblems
Basically without Mouse accel your mouse movement is 1:1. With mouse accel on the movement will be different depending on your hand movement. Some people dont notice it. But if you want the most precise aim in fps games its better to turn it off. But there are some pros who use it just cause there use to it..
It makes games ridiculously hard to play in my experience with it.
It basically measures how far you move based on how fast you move your mouse.  So if you move your mouse slowly 1 inch you will move that distance in the game, but if you move your mouse quickly 1 inch you will move farther than if you moved your mouse slowly.
It makes it a b***h to aim.
MY CURRENT PC
 CPU: Intel Core i7-4770k COOLER: Noctua NH-D14 MOBO: MSI Z87-GD65 Gaming ATX RAM: G.Skill Ripjaws 16GB DDR3-1600 STORAGE: Samsung 840 EVO 120GB SSD and Seagate Barracuda 1TB 7200RPM HHD GPU: Gigabyte G1 Gaming GTX 970 SLI CASE: Fractal Design R4 PSU: EVGA 1000W 80+ Gold
PERIPHERALS - KEYBOARD: Corsair Vengeance K70 w/ Cherry MX Browns MOUSE: Logitech G500/M100 MONITOR(S): Acer H236HLbid (I want an Asus PB278Q) SPEAKERS: Some Cyber Acoustics $10 speakers PICTURES AND FULL PARTS LIST @ PCPARTPICKER - http://pcpartpicker.com/b/z4Pscf
"Don't get so caught up in trying to make a living that you forget to make a life."
Never changed mouse settings other than sensitivity, and never had a single issue.
Yeah, it's already covered, though in terms of disabling it, you should find it in your Windows control panel called "Enchanced Pointer Precision," then you want to disable it further in any games that have support for it, and enable "Raw input" of the mouse.
[witty signature]
I tried it out, I'm used to super fast mouse sensitivities; so the acceleration is not that big of a deal, actually quite nice moving from one monitor to another (feel like a slug without it)
To each their own!
I guess I've mastered the "acceleration", i know how my mouse works.
Thanks for the explanation!
Yeah, but in competitive FPS games I absolutely hate it.
I'd rather have my crosshairs move the same speed rather than at different speeds dependent upon how fast I move my mouse.
MY CURRENT PC
