So I built my first computer about 2 years ago and I want to get into liquid cooling. I was thinking of buying a Swiftech H220X or a CoolerMaster Nepton 240M. I'd prefer the H220X but my main concern is that either it won't fit in my Cougar Evolution Case or that it will interfere with my CORSAIR Vengeance memory or my MSI Z77 MPower motherboard. I would like to hear your thoughts and opinions.
https://linustechtips.com/topic/272098-aio-liquidcooler-help/
if this is the case you are talking about http://www.cougar-world.com/products/pc_case/evolution.html then you shouldn't have an issue with 240mm or 120mm AIO's for the ram being an issue it wont be because watercoolers don't hang over the ram... if the motherboard is LGA 1150, 2011, 2011-3 you will be fine most if not all manufactures give you the different brackets for each socket
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/272098-aio-liquidcooler-help/#findComment-3691441
Pardon me if I'm being a newbie here but doesn't Swiftech's H220-X have a reservoir and Pump that hangs down from the actual radiator itself? That seems to be my only concern. Also, is $115.00 USD a good price for a new H220-X?
https://linustechtips.com/topic/272098-aio-liquidcooler-help/#findComment-3691686
oh sorry didn't look at the H220-X i guess that could be dependant on hardware in the way the nepton should have any issue however
https://linustechtips.com/topic/272098-aio-liquidcooler-help/#findComment-3691752
