Best specs for $2500
Go to solution Solved by extremescouter,
Okay thanks but for future reference will 2500 be enough for 2 780s and socket 2011
Should be. An i7 3930k is around $550 and the two GTX 780s would be another $1300. That leaves around $700 for your case, PSU, motherboard, hard drives and anything else, which is doable.
What are the best specs for gaming and a bit of editing I can get for $2500 no peripherals or operating system. Would I be able to get 2 780s with a lga 2011 processor or only one of them?
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/26957-best-specs-for-2500/
You could get two 780s. Since you'll be gaming there won't be a whole lot of benefit to going with the X79 platform.
I'll also be doing a bit of editing I'll add that
https://linustechtips.com/topic/26957-best-specs-for-2500/#findComment-342245
Haswell will probably suit you better if you're only doing a bit.
https://linustechtips.com/topic/26957-best-specs-for-2500/#findComment-342254
https://linustechtips.com/topic/26957-best-specs-for-2500/#findComment-342270
