Hello I want to build a new PC but I don't know what PSU I need.
My RIG:
- I7 5960X (I want to over clock it @4.4GHZ)
- 980 GTX
- Asrock x99 extreme6
- 32 GB DDR4 (8GO * 4)
- WD Green 6TB
- SSD Force GT 120 GB
- ODD
- Zalman CNPS12X FAN
- Zalman Z11 plus (5 * 120mm Led Fan + 2 * 80 mm Led Fan) all of these Fan connected to directly to mother board
I want to buy a corsair PSU is RM650 the best choise ?
and thank you ^_^
https://linustechtips.com/topic/269015-help-new-power-supply/
EVGA G2 750w
You should also get a better cooler....Noctua NH D15, Corsair H110, NZXT Kraken X61
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/269015-help-new-power-supply/#findComment-3653002
Evga G2 is going to be the best option for your no doubt, but you don't need 750w. If you plan on doing sli you can still get away with a 650. Single gpu a 450w is more than enough.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/269015-help-new-power-supply/#findComment-3653018
The Problem with Evga G2 750W that I can't put on the bottom of the case The FAN 120mm
Dimension  85mm (H) x 150mm (W) x 180mm (L)
With a 120mm fan installed, you are able to install a power supply up to 160 mm deep
If you have a power supply deeper than that, yo uwon't be able to install a fan on the bottom panel.
https://linustechtips.com/topic/269015-help-new-power-supply/#findComment-3653117
Thank you
so 650 Watt isn't enough ?
so the minimal PSU for my rig is 750W?
650w is enough for two 980s, but the 750 EVGA G2 is pretty much the best psu for the money.
What case do you have?
The Corsair AX760 is also an excellent psu, just not as cost effective: http://pcpartpicker.com/part/corsair-power-supply-ax760
PSU Tier List | CoC
https://linustechtips.com/topic/269015-help-new-power-supply/#findComment-3653147
