Internet problem
Go to solution Solved by Scratchy1215,
Yup it's on home network
trying to think what i had to do, have u tried using a different port from the router? or do u have a wireless adapter to try?
I finished building my PC, turned it on then the internet worked for a while, but it was only able to browse on bing any link I clicked on it wouldn't work. I now switched the Ethernet cable thinking it would solve the problem, it didn't solve it. Now I can't connect to anything except my router page. Windows say's that the ethernet is connected, but the internet just doesn't work... Since I can't Install the browser I just have IE saying "This page can't be displayed"
https://linustechtips.com/topic/267835-internet-problem/
did u get ur motherboard drivers installed off of disk or flashdrive? do that, i had the same issue and had to use my brothers laptop to connect to the internet to get drivers
https://linustechtips.com/topic/267835-internet-problem/#findComment-3636923
