HELP! Origin library empty.
Go to solution Solved by Jade,
Relog. Restart Origin. Reinstall Origin. Contact support. Probably in that order.
I just tried to load BF4 and it told me to enter my product code, I have already bought the game, installed and played it. I then went and checked my library and it's totally empty. I had over 20 games. I don't know what happened to them. Can someone help me?
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/267105-help-origin-library-empty/
Ok will give it a try, will post back if any of this works. Thanks.
Edit: Panic over, disaster averted. Thanks.
