It will go in, you just have to push stupidly hard lol. Try not to stress the motherboard though. I hate that about the 24pin connectors.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/266126-24-pin-connector-problem/#findComment-3615583
I'm using the Corsair PSU CX600M and MSI motherboard Z87-G45. The 24-pin connector of the PSU doesn't click to the clip although it goes all the way in. This causes shutdown to my computer whenever the connector is unstable and about to fall off.
If the locking problem is on the cable itself buy a 24pin extension cable. Tape the other end(where you will connect the 24pin to the extension) so that it wont fall off
i5 4690k @ 3.5Ghz | Stock Cooler :/ | ECS Gank Machine Z87H3-A2X EXTREME | Gskill RipjawsX 8GB 1600Mhz | MSI GTX 960 100th ME 2GB | Samsung 840 Evo 120GB | 1TB WD Caviar Blue | Seasonic m12ii evo 750W | Razer Modded Phantom 410
https://linustechtips.com/topic/266126-24-pin-connector-problem/#findComment-3616257
